CLDR Sample Exam Question
Hi everyone,
I was able to fix the problem myself. My confusion was because to the old  "Read from spreadsheet file" vi was working while the new one did not.
I guess the new version doesn't have the same functionality.
Message 21 of 25
(3,102 Views)
They work pretty similarly.  My guess is you have something else going wrong.  Check delimiter constant.  Are there any other characters in there that are non-printable or space?  That constant looks a bit wider than it should be.
Message 22 of 25
(3,099 Views)
Hi RavensFan,
You are correct. I used a string constant with space in it and that caused the issue I had earlier.
Message 23 of 25
(3,093 Views)
You are replying to something that was originally posted almost 8 years ago, has been marked as solved, and doesn't have anything to do with the original question. Can I suggest you start a new topic in the future?
Message 24 of 25
(3,073 Views)
It's probably more appropriate to post in the Certification Forum.  In fact, the forum is a gold mine of certification-related info.  Indulge and be enlightened!  🙂
Bill
CLD
(Mid-Level minion.)
Message 25 of 25
(3,053 Views)
