12-25-2017 08:44 PM
Hi everyone,
I was able to fix the problem myself. My confusion was because to the old "Read from spreadsheet file" vi was working while the new one did not.
I guess the new version doesn't have the same functionality.
12-25-2017 08:58 PM
They work pretty similarly. My guess is you have something else going wrong. Check delimiter constant. Are there any other characters in there that are non-printable or space? That constant looks a bit wider than it should be.
12-25-2017 11:37 PM
Hi RavensFan,
You are correct. I used a string constant with space in it and that caused the issue I had earlier.
12-26-2017 05:10 PM
You are replying to something that was originally posted almost 8 years ago, has been marked as solved, and doesn't have anything to do with the original question. Can I suggest you start a new topic in the future?
12-27-2017 08:51 AM
It's probably more appropriate to post in the Certification Forum. In fact, the forum is a gold mine of certification-related info. Indulge and be enlightened! 🙂
