CLAHE (Contrast Limited Adaptive Histogram Equalization) algorithm in LabVIEW?
Hello community!
I am working on a project which requires me to apply CLAHE to the image. I am wondering if LabVIEW can do things like this or not?
I found a vi called Histogram Equalization. However, after trying this, I don't think it's anywhere near the algorithm of CLAHE.
Moreover, I tried using DLL method mentioned in this post, still no luck.
Anyways, I am desperately seeking for help, don't know if LabVIEW is capable of performing CLAHE with its own vis or I need to find other methods to achieve this.
Here's the process:
I first use the line scanner (Keyence LJX8020) to scan a surface. Once I obtain the surface information, I convert it from 2D array to U16 image, as shown in Fig1.
Comparing Fig1 with Fig2, which is processed with CLAHE algorithm, the middle part is very different. It's missing a lot of details.
I also attach the test piece we use to scan below.
(2,382 Views)
Hi Billy,
It seems you forgot to attach all of your promised attachments…
LabVIEW is a full-featured programming language and you can implement any algorithm you need!
(2,354 Views)
Ah! You are totally right. I did forgot to attach the files. My apologies.
Here's the files!
(2,343 Views)
Accepted by Billy901104
If you're not into implementing the algorithm in LabVIEW, you could call the algorithm in Python from LabVIEW using the Python node.
Santhosh
Soliton Technologies
(2,340 Views)
Thanks for replying to my post.
Actually I wanted to implement the algorithm into LabVIEW. However, after weeks of trying, sadly still nothing. Guess it's out of my league.
I am looking for a quick way to do this and python node is a really good idea! I'll try it out later!
I already tried using MATLAB node but nothing. Maybe I'll have some luck on Python node.
Anyways, thanks for responding!
(2,323 Views)
