CLAD question help
All of the following statements are true, EXCEPT:
A
 You can make a Cluster of Clusters.
B
 You can make an Array of Arrays.
C
 You can make a Cluster of Arrays.
D
 You can make an Array of Clusters.
E
 All of the above statements are true.
My option would be ' E ' because by nullifying that statement , I indirectly nullify the second statement too , whereas If I select the option ' B ' , I would end up in agreeing that the fifth statement is True. But recently I found in one of the solved papers that the option was B. So experts kindly help !
Subramanian
LabVIEW Developer
Life may control my car, but I steer it ! !
Message 1 of 11
(4,725 Views)
Its already been discussed I guess. Try to make array of array I bet you cannot. (Option B)
Message 2 of 11
(4,722 Views)
Anand, Thanks for your reply.  I do accept that Option B is false. But by selecting that, wont I imply that I leave Option E to be true ?
Subramanian
LabVIEW Developer
Message 3 of 11
(4,718 Views)
Little confused. Need some time
Message 4 of 11
(4,712 Views)
Accepted by Aventador
Technically I agree that selecting E would imply that A-D are true, but it's not meant like that. If there is an answer like "all of the above statements..." then this is meant as kind of independant. So either one of A,B,C,D is false or, if none of them is false, choose E.
Message 5 of 11
(4,703 Views)
dan_U :  Thanks !  Now I'm relieved of the ambiguity
Subramanian
LabVIEW Developer
Message 6 of 11
(4,687 Views)
In the original question we have the statement B False (array of array) so what would be the right choise?
Message 7 of 11
(4,652 Views)
B.
E means that all A-D are true, which is not the case, since B is false.
I guess it was confusing in my previous post, what I meant was this:
if you select B this technically implies that E is true, which would be incorrect. But selecting E is incorrect as well. So E has to be treated in a slightly special way.
Message 8 of 11
(4,649 Views)
Hi Dan,
"Technically I agree that selecting E would imply that A-D are true, but it's not meant like that."
Logically you have to select options B and E, as both are not TRUE, as is asked for: "All of the following statements are true, EXCEPT:".
It's a pity we have to guess what NI is meaning by asking some questions! It's even more a pity as we aren't able to discuss CLAD results with NI nor do we get any results (apart of percentage value) presented by NI...
So the question (to NI) is: when will all those CLAD questions be nonambiguous? On my last CLAD test I also noted such a question to the NI representative observing the exam...
Message 9 of 11
(4,642 Views)
I fully agree, Gerd. B and E could be correct as well (technically they are), but I guess what NI wants to see is B.
Q to the OP: do you know whether multiple answers can be correct in that question?
Message 10 of 11
(4,634 Views)
