CLAD Questions
Hii friends,
Can any 1 suggest the answers for the Questions i have attached in it..........
Message 1 of 16
(5,879 Views)
I would say 28, based on the patterns available.  I hope to never see a subvi with that many connections!  Smiley Surprised
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 2 of 16
(5,867 Views)
My second app used a sub-VI with the worse case pattern. I had this weivbal of logic in a single VI. I selected the center of it and created a sub-VI from it. It ended up looking like a spider or should I call it a "Flying Spagetti Monster".
I have gotten better since then. Smiley Wink
Message 3 of 16
(5,849 Views)
Did you try opening a blank VI and seeing how many terminals are on the densest pattern?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
Message 4 of 16
(5,807 Views)
Mike actually for a blank Vi is 12 but in the Question they mentioned a sub vi can hold up to how many terminals........so it is 28 only  yaa
Message 5 of 16
(5,794 Views)
For the 3rd que, Bundle by Name is the correct answer.
- Partha ( CLD until Oct 2027 🙂 )
Message 6 of 16
(5,790 Views)
I had 1 question called where we can adjust the gain in DAQmx.....
Message 7 of 16
(5,792 Views)
Can u say the answer
Message 8 of 16
(5,782 Views)
If you have LabVIEW why don't you try to find the answers? For this question just open a blank vi and place a cluster box on the front panel. Add a string control, a numeric control and a boolean control into the cluster box. Right click the border of the cluster and choose reorder controls in cluster. Smiley Wink
Now Using LabVIEW 2019SP1 and TestStand 2019
Message 9 of 16
(5,771 Views)
'A' is the correct answer.
We dont need to reorder the cluster elements' order when we delete/remove any/some controls/indicators from it.
Message 10 of 16
(5,757 Views)
