CLA-R Sample Exam Question 22
@JÞB wrote:
@Intaris wrote:
Canyou even parallelise loops which don't have autoindexed inputs?  I thought you could only properly paralellise a for this reason (As the loop is currently written).
Shane
Yes, you can. In all cases # of iterations must be determistic (No conditional terminal) but that is true for any for loop without a conditional terminal that does not break the compiler.
And there can't be any dependance of previous iterations.  If doing in-place operations, the iterations are not dependant on the previous iterations.
Message 11 of 15
(933 Views)
With 1 notable exception: You will get a warning if parallizing a for loop containing Random. because the seed is internal to the function there is a dependancy internal to the history of random calls.  You'll still get the same values but in a different order in the output unless you enable debugging. (Forces sequential iterations) Trivia for the masses.
"Should be" isn't "Is" -Jay
Message 12 of 15
(909 Views)
More than 1, there are a number of nodes that have side effects in parallel loops, not just Random.  Off the top of my head I know of Get Date/Time in Seconds and Tick Count.
Message 13 of 15
(901 Views)
I wouldn't really consider Random to be dependent.  You truely want something random after all.  But it does make sense that it comes out as a warning due to random functions not truely being random.
Message 14 of 15
(895 Views)
Thank you everyone for the explanations.   In the past I have just blindly looked at the shift registers and told myself that iteration parallelism would not be beneficial.  I will be more attentive of the index and replace operation in future.
Herrlin
Just trying to spread the LabVIEW love.
Message 15 of 15
(885 Views)
