CAN system setup
Hello Friends,
I have a
1   cDAQ 9178,
2  High speed CAN FD module (NI 9862),
3  CAN Breakout Box,
4 CAN Cable (With Power Terminals).
I need to connect all these , I need the connection diagram ..
(4,039 Views)
Hi friend,
did you read the manual of the NI9862 module? And the manual of your cDAQ9178?
I guess the answer(s) are found in there…
(4,031 Views)
thats fine ,
but how to connect the CAN module to CAN breakout box through the CAN cable( with power terminal ) and where to give the power and how much ?
(4,019 Views)
Hi chintamani,
again: did you read the manuals? Like this one found on the product page of the NI9862?
The breakout box has it's own product page and the supply is also mentioned…
(4,013 Views)
Well I am done with hardware setup.
my next point is to send  a CAN command and how to configure a CAN hardware to communicate..
(3,951 Views)
Hi chintamani,
after you read all those manuals you should have heard about XNET!
Open the XNet example VIs in your example finder to learn how to use your 9862 module in LabVIEW!
(3,937 Views)
