CAN MSG PAYLOAD: Will I need to configure for 2 bytes if I need a 9 bit msg
Each element of the payload array represents one byte. That's all. You can view that byte in decimal, hex, binary. You might find it helpful to right-click the numeric constant (the blue-bordered payload array element) and show the radix, then click the 'd' for decimal and change it to 'b' for binary.
Message 11 of 17
(1,920 Views)
In response to your statement:
Your "CAN MSG Properties" image is on the right track. The only thing unknown here is the placing of the data in the message: you might stuff 2×9 bits like you do in your "message overview" - but I guess using 16bit entries for each accelerometer value is more probable…
After looking this over, it appears to me that using 9 bit entries would be somewhat complex and 16 bit entries would be the better way to go. Do you agree? Thanks!
Message 12 of 17
(1,896 Views)
Hi sfrosty,
when I can design my own CAN messages I try to stay at byte boundaries, using bytes or words per signal.
In case I'm limited in "space" (available message IDs) I also use nibbles (4bit entities). When there are single bits (like error flags) I stuff them in one byte.
In your case I would either use 3 words (16bits per signal) or 3× 12bit signals using 48 or 36 bits of the full 64bit frame…
Message 13 of 17
(1,894 Views)
Kool!
How's this:
attached
Message 14 of 17
(1,891 Views)
Accepted by sfrosty
Hi sfrosty,
now it looks ok - as I suggested using 3× 16bit signals…
Good luck!
Edit: to manage CAN message definitions I can recommend CANdb++ from Vector. This tool is available for free!
Message 15 of 17
(1,884 Views)
@GerdW wrote:
Hi sfrosty,
Good luck!
Just wanted to Thank You again!!!!! from sfrosty
Message 16 of 17
(1,842 Views)
@nathand wrote:
XNET Read returns an array of frames - an array of clusters, where the cluster structure represents a CAN frame, and each frame is one array element. Within the frame cluster, the "payload" element is an array of up to 8 elements. So, when you tell it to read N frames, you get an array of N clusters, and each cluster contains a payload of up to 8 bytes.
Just wanted to thank you again! from sfrosty
Message 17 of 17
(1,841 Views)
