C28x IQmath Library for LabVIEW
My colleagues are using Texas Instruments TMS320C28x IQmath Library to convert HEX values into actual value.
They program in C/C+, I would like to do the same with LabVIEW for my own testing purposes.
Does LabVIEW have a library similar to this or this can be implemented somehow?
(667 Views)
If you have the C dll, you can call it in LV to do the same conversion. From just the term it looks like some logic that TI used and only TI can provide an equivalent in LabVIEW (or at least explain the logic to implement in LV).
Santhosh
Soliton Technologies
(660 Views)
Hi Dawn,
@FaIlingDawn wrote:
My colleagues are using Library to convert HEX values into actual value.
  • Which "HEX values" do you need to convert? How are those values represented/formatted in your data?
  • What is the "real value" of a "HEX value"??? Why is there a difference?
Probably yes.
But you need to provide more information about your input data and the expected output data…
(621 Views)
