C++ to LabView
What is the equivalent VI of the next C++ code?
ret = ret << 8;
Thank you guys
Message 1 of 13
(4,388 Views)
Look at the logical shift function in the Numeric / Data Manipulation Pallette.
Message 2 of 13
(4,386 Views)
I can't to find the right expresion. can you help me?
thank you
Message 3 of 13
(4,375 Views)
See here.  You can also use the search function on the palettes and search for "logical shift".
Message Edited by Ravens Fan on 12-10-2008 03:49 PM
Message 4 of 13
(4,361 Views)
Once you know (or have an idea of) the name of the function, hit the "Search" button and start typing.  LabVIEW will help you find it.
Jim
Message 5 of 13
(4,336 Views)
The Logical Shift is x << y and I need  x>> y
how can I do that?
thanks
Message 6 of 13
(4,303 Views)
I have this on:
wrbuffer[4] = (address >> 24) & 0x000000ff;
where "address" is int
what it's the LabView equivalent?
thank you
Message 7 of 13
(4,295 Views)
Select help for the Logical Shift function then select detailed Help.
y can be any numeric representation. If y is greater than 0, the function shifts x left y bits (from least significant to most significant bit) and inserts zeros in the low-order bits. If y is less than 0, the function shifts x right y bits in the positive direction (from most significant to least significant bit) and inserts zeros in the high-order bits.
Visualize the Solution
CLA
LabVIEW, LabVIEW FPGA
Message 8 of 13
(4,292 Views)
Thank you VADave but still I can't to find the answer for:
to labView
Message 9 of 13
(4,288 Views)
Jim
Message 10 of 13
(4,283 Views)
