Burst Measurement
Modulate Burst Detection with very low SNR < 32 dB.
Burst period = 100 ns
Frequency modulation 10 ns.
period between 2 burst 1 ms.
The system must detect this burst specified up and generate a TTL signal synchronised to time detection.
Thank you for your help
(3,659 Views)
I am not sure what your question is!
Check out NI's high end scope cards. They may be able to handle this using hardware triggering.
Please elaborate if I am out in left field.
Ben
Ben Rayner
Certified LabVIEW Developer
www.DSAutomation.com
(3,659 Views)
This application is the anemometry laser.
We must detect speed particle.
The signal is a burst modulated at fd=150 MHz.
the mathematical signal is :
s(t)=Aexp(-fd^2*t^2*m^2)*cos(2*pi*fd*t)+(gaussian noise).
This signal is generated randomly (period max 1 ms)
I numerise this signal at BP = 500 MHz.
I think with FPGA or/and NI card recognise this signal mixed with noise (32 dB) and parasite burst for trigging an other acquisition system and record only the good burst.
I hope exist one solution without hard development.
Thank you for your help.
(3,659 Views)
Sir,
This sounds like an application that is within the range of either the NI 5112 or 5122 Digitizer (High End Scopes). Here is a Tutorial regarding similar applications called "High-Speed Event and Defect Detection with Real-Time Response".
http://zone.ni.com/devzone/conceptd.nsf/2d17d611efb58b22862567a9006ffe76/3a67e74929eb663986256ae2005c6c1d?OpenDocument
The NI 5112 two-channel high-speed digitizers from National Instruments come with unique event detection capabilities that can detect events or transient signals continuously over months and timestamp these events with nanosecond accuracy. With a maximum sampling rate of 100 MS/s, an analog input bandwidth of 100 MHz and deep memory of up to 32 MS/channel, an NI 5112 can digitize thousands of transi
ents with resolution high enough to extract detailed information from the signal.
I believe that NI products can perform this operation. However, I recommend you contact National Instruments at 1-800-433-3488 and discuss this application with us. Depending on your application a PXI-5112 or 5122 might be suitable.
Robert Jackson
(3,659 Views)
