Built installer fails - older version of winMIF
Thanks very much for your help.
I have successfully built an installer.
J. Heerema, PhD - LabVIEW specialist
Message 21 of 36
(3,904 Views)
Thank you for the updates.
Scott Richardson
https://testeract.com
Message 22 of 36
(3,901 Views)
I am experiencing the same problem
LabVIEW 2017. Used the Automatic Recommended option
I applied the NI ADE Deployment Support Update
Installs on a PC with LabVIEW Installed
Fails on a PC with NO LabVIEW Installed
Thank you, Jeff
Message 23 of 36
(3,856 Views)
Jeff, please review Wes' post (Re: Built installer fails - older version of winMIF) and go through his steps and reply here with your finding.
Scott Richardson
Message 24 of 36
(3,843 Views)
Good morning Scott,
Please find attached NI-list-install file and MetaBuilder version.
Update:
I successfully installed the App on a laptop with no previous NI SW.
It seems there is something preventing an install on the Lab PC.
Thank you, Jeff
Message 25 of 36
(3,816 Views)
Hi Jeff,
Thanks for posting that debug info. I can confirm that the KB patch installed successfully, so that is probably correct. It also seems that you were able to run the built installer on one machine, so that also helps confirm that your build machine is in a fixed state - great.
But, seems like you're getting some error on a different (lab) machine? Some things to try or share:
  • What error are you seeing?
  • If it's an error in the .NET 4.8 installer that is running first, try rebooting first then retry, as the Microsoft .NET installer is sometimes fragile.
  • On the lab machine that is seeing the failure, pass the following command to the built installer to get a debug log, and reply with it here:  install.exe /log %temp%\deployment_log.txt
- Wes
Message 26 of 36
(3,806 Views)
Good morning Wes,
Working with IT managed computers.
Getting a Sandbox computer that I can experiment on soon.
Below is Error installing on Lac PC.
Lab PC does not have any NI SW installed.
Thank you, Jeff
Successful Install dotNet Version (4.8.04084)
Unsuccessful Install (lab PC) dotNet Version (4.8.09037)
Message 27 of 36
(3,789 Views)
Jeff,
This is a bit puzzling, as what version of .NET is already installed on the system does not matter. The cause of this error message is a self-check within that built installer that it is new enough to handle the version of .NET that it includes (and the KB patch updates the binary so that is it new enough). As such, a particular build of an installer should succeed on 100% of machines, or fail on 100% of machines.
Some things to check:
  • Ensure that you have rebuilt this installer (in LabVIEW or whatever NI ADE you are using) after applying the KB so that it includes the updated binaries.
  • That the version of install.exe at the root of the built installer is 22.8 or greater.
  • For the built installer that works on one machine, ensure that you are running that exact same (fixed) installer on the other machine as well.
If that doesn't resolve the error, please attach a zip of the following from the built installer:
  • install.exe
  • install.ini
  • supportfiles\merged.cab
- Wes
Message 28 of 36
(3,776 Views)
Hi Wes,
Update - Install succeeded in a sandbox laptop provided by IT.
Will post when I have something new.
Thank you for your support, Jeff
Message 29 of 36
(3,682 Views)
I am having a similar issue with the older version of winMIF.  I am installing a 2019 version of an executable. Ran the NIADE Deployment Support the INI.exe version 23.3.0.49294
Below is a snapshot showing the metabuilder.dll in the x86 national instruments shared MDF BinRTE folder and the deployment support install exe details.
Built the install after running the patch. Still receive the not compatible with Net 4.8
What am I missing?  Thanks
Message 30 of 36
(2,700 Views)
