08-02-2024 10:39 AM
Hello I cannot install my application.
I have followed the recommendations. I have tried in 3 different laptops, 1 of them have Labview installed. I am currently sending the data from one of the laptops without it.
I confirm that it says "no operation..."
at first there were some packages and I installed them. I am not sure what this advice means "If it does not show the above message, but appears to install some packages, please retry your build and install in LabVIEW - as it might be fixed now." What do you mean to retry the build and install in LabVIEW?
I still get this problem:
and here is the details of the .dll
I have this features in my laptops:
As I said, this happens in 3 laptops already. I dont know what do to. Could someone help me with this?
08-02-2024 10:50 AM
Forgot to say, unfortunately I cannot share the installer due to company policies. Do I have to install LabVIEW? I have never used it, I just need to run the application as a user
08-02-2024 11:08 AM
See WinMIF Not Compatible With .NET 4.8 Error When Deploying Custom Installer for more information on this issue.
08-08-2024 03:56 AM
I tried every step that's in this post, but the issue still persists. Installing NI ADE Deployment Support didn't work. Is there any other solution? Thank you.
12-16-2024 12:12 AM
I'm trying to download this zip, but this zip is invalid.
12-29-2025 03:18 PM
Megathanks Scott!
I just ran into this problem recently using LV 2022Q3 to build applications for clients here at UMN. College of Science and Engineering has stopped investing in newer versions of the research site license. Followed your link, ran the installer, and it fixed the problem.
