Building application in UNIX
My problem is that graphical objects like the "knob" doesn't turn up
on the panel in the standalone application. They are there, but they
are not visible. Also all beautifying shadows and most added colors
are gone.
I build my application using the "Build Application or Shared Library
(DLL)..." tab under Tools in Labview 6i, I'm working in an
UNIX-environment.
I tried to add extra lines in the labviewrc-file specific for my
application but without any positive result.
Any suggestions?
(3,598 Views)
I can not give you a solid "been ther done that" answer.
I can offer a clue.
"mesa.dll"
is used to support the 3-d graphics.
Make sure you have that .dll.
Ben
(3,598 Views)
Ben wrote in message news:<5065000000050000005D010100-1042324653000@exchange.ni.com>...
> I can offer a clue.
> "mesa.dll"
> Ben
Thanks for the tip Ben.
I assume I have support for the 3-D graphics on the computer, since I
run it on the same computer as Labview. The graphics works fine while
developing the program, but not with the standalone program.
I'm using UNIX so I don't think there is a problem involving a Shared
Library.
Any other suggestions?
(3,598 Views)
> Library.
Actually, I think Ben is correct. It isn't a DLL, but a shared library.
Running an EXE built by LV, it dynamically tries to load the mesa
library. If it doesn't find it, it goes ahead, assuming that you pared
the distribution down on purpose.
I believe there should be a redistributable runtime installer on the CD
shipped with LV. If not, you can get it from the web site. It will
place a few resource and libraries in a common location where
all LV
EXEs can find them. The LV editor/development system doesn't currently
use those same libraries.
Greg McKaskle
(3,598 Views)
Sorry about the dll thing.
I did get the mesa part right.
Ben
(3,598 Views)
In article <3EF99FBE.3070209@austin.rr.com>, "Greg McKaskle"
> place a few resource and libraries in a common location where all LV
> Greg McKaskle
My two cents. I've run into this problem on my Linux system. Buttons
didn't show, etc. I've upgraded to 6.02 and the problem persists.
Guess I'll check out the NI site for upgrades...
-Kevin
(3,598 Views)
Ben wrote in message news:<506500000005000000E4010100-1042324653000@exchange.ni.com>...
> Ben
Thanks guys, I'd better try this out as soon as possible!
cheers,
P-A
(3,598 Views)
