Building a report
Hi all,
i´ve tried to build a report with these report vi´s for the first time.
Because of this i´ve looked at the sample report vi´s first,
but it seems that none of these is working (lot´s of error messages, eg:
subvi isn´t executeabel).
So - why??? Has anyone the same problem???
Are the sample vi´s bad???
Btw, i use LV6.0i
MfG / best regards
M.Waschk mailto:waschk@mavd.de
(3,394 Views)
You'll need to read the documentation to see what you need to define. There may be certain variables that you need to define before running it.
I tried the "Simple Test Report" example in LabVIEW 6i and it ran fine.
Which example are you running?
Shan Pin Koh
(3,394 Views)
i´ve tried "Text Report Example.vi", "Sample Test Report.vi" and "Example
HTML Report.vi.
MfG / best regards
(3,394 Views)
I ran the examples that you mentioned and they were fine for me. Do you have Report Generation toolkit installed properly? You might want to reinstall that Toolkit. When you click on the error list, what does it tell you? Check the file location of the VIs. They will give you a clue of what might be the root of the problem.
Shan Pin Koh
(3,394 Views)
Yes, I've had that problem. What you need to do is delete the LVRT information and reload LVRT (includes report generation) from the files stored at NI's site. the exact step-by-step instructions are there as well.
(3,394 Views)
didn´t found it... Where do i have to search at NI site???
MfG / best regards
(3,394 Views)
Okay, I finally found it. Here is the information sent to me from NI tech support:
1. delete NI-Report from my registry
2. delete the folder named ni-reports from ..\National Instruments\shared
3. reinstall the LV 6 Run-Time Engine from the ftp site: http://www.ni.com
-> downloads -> drivers and updates -> LabVIEW
Hope that this helps. It worked for me anyway.
Rob C.
(3,394 Views)
