Builder install problem
Builder 6.1 will not install. The error message is "Unsatisfied Dependencies:LabVIEW 6.1 is required to use the Application Builder".   LabVIEW 6.1 is installed and runs.  Thanks. 🙂
Message 1 of 8
(3,925 Views)
Hi ,
Looking at the error message it looks like you are trying to install application builder on a machine that does not have LabVIEW installed? If this is the case then please be advised that Application Builder is an add-on to LabVIEW and requires pre-installation of LabVIEW.
Hope it helps,
Ankita
Message 2 of 8
(3,911 Views)
LabVIEW 6.1 is already installed and been in use for years. The install program for Application Builder 6.1 does not agree with that fact though. 🙂  If I knew what the App Builder program was looking for in the windows registry or in the LabVIEW 6.1 install directory then maybe I could do something. Reinstalling LabVIEW does not fix the problom.
Message 3 of 8
(3,906 Views)
stupid question but worth asking.  Does the person installing the app builder have local admin rights on the computer in question?
Paul
Message 4 of 8
(3,902 Views)
Yep. I'm the owner and have never had a problem installing software.
Message 5 of 8
(3,888 Views)
I would suggest trying a uninstall and reinstall of LabVIEW 6.1 and then an install of Application Builder.
Ankita
Message 6 of 8
(3,873 Views)
Yep. Done that a few times using default install settings. I think the registry entry(s) got corrupt so the App Builder doesn't think LabVIEW is installed but since the App Builder doesn't give a clear enough error of what it's looking for my hands are tied. If I knew what to look for in the registry I could most likely fix it or verify it's there, that is if thats where the problem is. Thanks.
Message 7 of 8
(3,867 Views)
Thanks for trying out my suggestion. I think at this point its best that you contact National Instruments technical support team via phone/email and I am sure we will be able to help you out.
Ankita
Message 8 of 8
(3,855 Views)
