Build error when using custom error codes
Devin,
Here it is.
Mark
Message Edited by mprimrose on 03-11-2008 04:20 PM
Message 11 of 13
(905 Views)
Hmmm...  I seem to be getting the same error with whatever error code file I use.  The first time the build gives an error, any subsequent build will work (which is what the original poster was seeing as well).  Does it work for you if you build a second time immediately after the error?
I tested out the functionality in LabVIEW 8.2 and it seemed to work fine, so this might be an issue with LabVIEW 8.5.  I'll look into it further and report it to R&D if neccessary.
Message 12 of 13
(880 Views)
Devin,
Yes it works fine the second time you build it.  The first time I always get an error.
Mark
Message 13 of 13
(875 Views)
