06-10-2024 07:08 AM
I got this return from an API GET call
{"records":[{"id":"recxfXKnsWbSIFm8k","createdTime":"2024-06-10T11:27:34.000Z","fields":{"Name":"BRBNUD385968 - 277"}},{"id":"recjsUHMUoXE4ZzQA","createdTime":"2024-06-10T11:47:03.000Z","fields":{"Name":"BRBNUD385968 - 510"}}]}
And I need to remove from the string, only "Name" and the corresponding value of it
The return of this API is dynamic, that is, they can have from 2 to infinite "Name" and I need all of them
Can you help me with this?
Solved! Go to Solution.
06-10-2024 07:22 AM
Hi Leandro,
Search the string for "Name":" (including quotation marks), then search for the next "/quotation mark and keep the substring before to get the Name value…
Use a loop to repeat the step above until there is no "Name" found anymore…
06-10-2024 07:28 AM
If you are not against using regex, you can use this:
Then just add a While Loop for searching all occurrences in the input string.
06-10-2024 07:29 AM
It is easy when you use JSONText, because it understands JSONPath notation.
Not sure if you really meant remove or rather extract, here is both:
06-10-2024 07:48 AM
Thank you, work's well i need
