Build Specification Advanced Window
Would anyone know why my advanced window in the build specifications dialog looks like this.  I cannot access all information.
Ed
Message 1 of 8
(6,180 Views)
What LabVIEW version is this? What OS?
E.g. Do you have any unusual font settings in your windows theme?
Message 2 of 8
(6,170 Views)
Well that's strange. I would call this a bug because NI should have accounted for whatever causes this. It looks like all of your text is slightly larger than mine. Have you checked your font settings in Tools > Options > Environment > Fonts?
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
Message 3 of 8
(6,168 Views)
LV2013  Windows 7 64 bit
Message 4 of 8
(6,152 Views)
Accepted by topic author edwardMKS
Click the Windows Icon (Start) button on desktop, type "Font Size" and hit enter, then change Windows Default Font Size to 100%
CLD | CTD
Message 5 of 8
(6,149 Views)
Thank you.  Changing the font size to 100% worked. (Note that default is actually 125%).
This seems to be a bug as I would expect the dialog to adjust as other dialogs adjust.
Message 6 of 8
(6,135 Views)
So this happened to me literally last week, the default I think is set by Windows OS depending on what resolution monitor you're working with, some people I work with have their (Default) (set by Windows) to 100%, where in both your case and mine, it was set to 125%..
Either way, glad this was the solution!
CLD | CTD
Message 7 of 8
(6,133 Views)
I was thinking of your forum post when this came up, "Can there really be two posts in 1 week with the same font issue..??"
Cheers
Message 8 of 8
(6,126 Views)
