Online shopping is currently unavailable.
Please contact us for help or try again later.
Build .NET Interop Assembly
Now, I'm not sure about my name!
This is the right version of the project.
About VB.net I'm a noob...
Code:
Imports System.Windows
Imports nsfiltroBW
Public Class Form1
    Private Sub Button1_Click(sender As System.Object, e As System.EventArgs) Handles Button1.Click
        Dim ingresso(2000) As Double
        Dim j As Integer
        Dim uscita(2000) As Double
        For j = 0 To 2000
            ingresso(j) = j
        Next
        'usando la DLL
        'Dim prova As New nsfiltroBW.cnfiltroBW()
        uscita = nsfiltroBW.cnfiltroBW.filtroxVB(uscita, ingresso)
        Dim presi(2000) As Double
        presi = uscita
    End Sub
End Class
Message 11 of 19
(3,167 Views)
The line
is incorrect. Since the function takes in an array as the first parameter, and modifies it, you need to pass the array by reference. This is done by using the keyword ByRef. Thus the line would be
nsfiltroBW.cnfiltroBW.filtroxVB(ByRef uscita, ingresso)
You should not be returning the array as the function's return value if you're already passing it in as a parameter of the function.
Message 12 of 19
(3,157 Views)
 this expression doesn't work: "Expression expted." ByRef is underlined in cyan.
Thank you! 🙂
Message 13 of 19
(3,153 Views)
Sorry. Not sure where my brain was. I program in C#, not VB.NET. The line nsfiltroBW.cnfiltroBW.filtroxVB(uscita, ingresso) should be fine.
Message 14 of 19
(3,150 Views)
But it doesn't work and I don't understand why...
Message 15 of 19
(3,149 Views)
I don't know how you can expect anybody to help when all you say is "it doesn't work" without providing any details as to what, exactly doesn't work. If I went to my car mechanic and said "my car doesn't work, what will it cost to fix it?" he'd probably just laugh at me.
Message 16 of 19
(3,146 Views)
I said it in a previous post: "There is no error but, when VB calls the library, it opens a white labview interface and it stops to work (no feedback, just this interface)." 😛
I also add a capture of my screen to make it clear 🙂
Message 17 of 19
(3,143 Views)
Accepted by topic author teoprimo
Sorry, I thought you were talking about getting an error in the VB.NET code. Did you copy the "data" folder that is created by the build of the interop assembly into the VB.NET folder? This folder contains the LabVIEW Advanced Analysis library, which contains the filter funtion your LabVIEW code is using. Thus, your interop DLL and the "data" folder should be in the same folder as the VB.NET application.
Message 18 of 19
(3,136 Views)
Ok! You win! 😄
It's easier than I think!
I'm surprised...I've added .dll to the project and VB.net takes a copy of it in project folders without "data".
I suppose that it calls library position and doesn't copy .dll!
Thank you so much
Message 19 of 19
(3,130 Views)
