Build Errors 1502
When I build EXE from LV source, I got error 1502, Here is the detail:
An error occurred while saving the following file:
E:\NIIFRIO\NI-5640R VIs\subVIs\ni5640R ADC read_write.vi
Invoke Node in AB_Source_VI.lvclass:Close_Reference.vi->AB_Build.lvclass:Copy_Files.vi->AB_Application.lvclass:Copy_Files.vi->AB_Build.lvclass:Build.vi->AB_EXE.lvclass:Build.vi->AB_Engine_Build.vi->AB_Build_Invoke.vi->AB_Build_Invoke.vi.ProxyCaller<APPEND>Method Name: <b>Save:Target Instrument</b>
Possible reason(s):
LabVIEW:  Cannot save a bad VI without its block diagram.
The "ni5640R ADC read_write.vi" is copy from an example of 5640R. If I build this vi separately, it is OK. I have recompiled all the VIs in my project and nothing helped.
So what can I do now?
Message 1 of 11
(6,743 Views)
Hi!
I had a similar problem a couple of weeks ago using LV2010.
It was probably due to a case structure with a constant wired on the selector.
Removing it was enough to let me build the executable...
Let me know if this helps,
Marco
Message 2 of 11
(6,722 Views)
Hi: I check the vi and find there is no case structure in this specific vi. I build the vi only it is successful. And I also build some simple examples that contains this vi, it is successful. If I remove the block diagram of this vi and only keep the input/output, it is successful. My platform is LV 8.6 Is there any suggestion ? Thank you very much.
Message 3 of 11
(6,700 Views)
Had the same bug once (lv85). Had to build exe with the problem vi front panel opened. Or with the checkbox "modify project library file after removing unused members" removed.
Message 4 of 11
(6,499 Views)
I got bit by this bug when converting to LV2010 (from 8.5).  Took me a while to figure out the specific problem because it takes about 10 minutes to compile my exe and I had to try multiple times to get it plus trying other things such as building an exe with just the offending VI but with no success.
Turns out the problem went away when I changed the case selector with a constant connected to it into a diagram disable structure.
Bruce
Message 5 of 11
(6,415 Views)
I update my LabView from 8.6 to 8.6.1. It seems OK now.
I do not find the problem and still worry when this will happens again.
Message 6 of 11
(6,399 Views)
Thanks Marco,
Had the same problem and again it was a case structure wired up with a constant.  I would mark it as a solution although I am not sure if it is the same in all instances.
This was moving the project from a 2009 to a 2010 build.
Craig
LabVIEW 2012
Message 7 of 11
(6,198 Views)
I had the same problem - saw your post - removed the hard wired case structure and my problem went away.
Much thanks!
Message 9 of 11
(6,055 Views)
Also see here:
http://forums.ni.com/t5/LabVIEW/bleep-you-error-1502-shakes-fist/m-p/2252430
Certified LabVIEW Architect
TestScript: Free Python/LabVIEW Connector
One global to rule them all,
One double-click to find them,
One interface to bring them all
and in the panel bind them.
Message 10 of 11
(5,729 Views)
