Build Array
the "Objective" picture is what i need to get at the front panel but from what u can see from the "Current" picture i only got the rows at the array i need to get the rows and columns at the array which is shown at the "Objective" picture
Message 21 of 46
(2,286 Views)
Place an empty array constant on the diagram.  Place a string constant inside of the array constant.  Since you need a 2D array, right click on the array index terminal and select Add Dimention.  You will then have a 2D string array to wire into the array type terminal.
Message 22 of 46
(2,284 Views)
Message 23 of 46
(2,279 Views)
Does not look lik an array, so no, it is incorrect.
Please crop your images to the intersting part!
Message 24 of 46
(2,273 Views)
Does it work for you?
(Please don't make such large screenshots with so much empty space.  Cleanup the image in Paint.  Or better yet, use the Code Capture Tool.)
I would recommend looking at the online LabVIEW tutorials
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
Message 25 of 46
(2,272 Views)
alright thanks can i ask if there is such a thing called"DBL Numeric Constant cos i can only find "Numeric Constant"?
Message 26 of 46
(2,268 Views)
Drop the numeric constant, then right click.  Representation, then Double.
Message 27 of 46
(2,264 Views)
You can right-click any numeric constant and pick the desired representation, e.g. dbl.
Message 28 of 46
(2,263 Views)
i solved my problem for my array part but after that i need to generate the results for IRAD and Input Power for Thinfilm.Can u guys help me take a look at my block diagram to see what i have done wrong?Below is my programming file.
Message 29 of 46
(2,234 Views)
What kind of help do you expect?  What is wrong?
Message 30 of 46
(2,215 Views)
