Build Array Function to create 3D array?
Well in Labview, I can create a 2D array just fine. But I am having trouble building a 3D array. Is there a means of doing this through the Front Panel like one would go about creating a 2d Array? Or can I use the Build Array Function to do this?
(5,639 Views)
Hi ShogunOrta,
You can create 3D array using front panel or use build array to create 3D array.
1. Using front panel
Drag down the indexer of an array to have 3 indexer. This is similar to when you create 2D array
2. Use build array
You can use build array to create 3D array by input 2 2D array to a build array function
TuiTui
(5,630 Views)
You can also use the Initialize Array function to create the N dimension array of your choice by expanding the 'dimension size' terminal of this function.
- Partha ( CLD until Oct 2027 🙂 )
(5,622 Views)
Thanks Tui Tui and Parthabe. I've tried all those options and they all work. I don't know. In terms of creating it right on the Front Panel, I think I had a brain fart. It's so easy! But again, thanks.
(5,611 Views)
