Build Aplication
What is that you cannot obtain? And what code? The exec file?
Message 11 of 23
(1,202 Views)
I have similar problem.
My project is working perfectly in Labview. There is a invoke node to open and close another VI from which I collect properties for COM ports and save them into XML file. After I build an aplication from this and then run the exe file, the application works fine until I click on button which calls another VI. Then everything freezes. I have to close the app.
I changed absolute paths with relative ones, but it wasn't better. VI which the application calls was set to be Always included in build properties.
I have no clue what to to to fix that.
Thank you for any help.
Message 12 of 23
(1,174 Views)
Have you tried the solution in this thread?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 13 of 23
(1,150 Views)
yes.
Message 14 of 23
(1,145 Views)
Post the code that opens the VI.
Message 15 of 23
(1,141 Views)
Have you varified it's location?  Is it placed where you expect it to be (Source File Settings)?
Message 16 of 23
(1,139 Views)
in source file settings I put it in ALWAYS INCLUDED, because I have read before that if you call a vi with invoke node you have to do this.
Message 17 of 23
(1,137 Views)
Yes.  But can you attach your code that is calling the VI?
What I mean by my ealier post is, doule-check your setting in Source File Setting and make sure it is pointing to the correct location (data folder).
Message 18 of 23
(1,131 Views)
tomorow, I am allready at home right now 🙂
Message 19 of 23
(1,127 Views)
this is how i open the vi.
Message 20 of 23
(1,115 Views)
