Bug when i press key <TAB>
How to reproduce this bug:
In new VI, create a Control Boolean and a Tab Control on the front panel.
On the bloc diagramme -> insert this controls in while loop.
Right click on Control boolean -> properties -> Key navigation -> Click on " skip this control when tabbing"
Right click on Tab Control -> properties -> Key Navigation -> Click on "skip this control when tabbing"
Edit -> Set tabbing order -> choice order 0 for boolean and 1 for Tab Control
Now move boolean on tab control and execute.....
When you press Key <Tab>, there is a bug.
How to fixe this probleme..?
I want to disable key tab, but i have a lot of control.... there is an solution for disabled key tab just one time?
I'm working with Labview 8.5.1 but i tried this with Labview 2010 student and there is a bug also.
thank you for your assistance !
Smiley Happy
(I give you an exemple, juste execute and press <TAB>)
(2,882 Views)
Exemple :
(2,879 Views)
Accepted by topic author o__o
This is an interesting bug.  I'll have a look into it and possibly file a corrective request.
One idea could be to filter the Tab key press before LabVIEW handles it:
Peter D
(2,870 Views)
thank you for your help ! this is what I wanted Smiley Very Happy
(2,805 Views)
