Bug in "Delete From Array"
I Was trying to delete all elements from an array using "Delete From Array" by connecting rows & length. Since I have deleted all elements from array, the output "Array w/ Subset deleted" should be empty and its expected  array size is "0*0". But here output array is empty, and its array size is retaining as source array size. What will be the reason for this. Is it a bug?
Here am attaching the image also.
Message 1 of 11
(2,102 Views)
This output IS empty (as per your image), so what's the problem?
Paolo
Message 2 of 11
(2,096 Views)
For a multi-dimentional array, its size is the product of all of the dimension sizes.  So the number of elements in your "deleted array" is 0 x 3 = 0.
An interesting "experiment" to try is to delete by columns instead of by rows.  My guess (I'll let you find out if I'm right) is you'd end up with an array of 2 rows and 0 columns, whose size is also 2 x 0 = 0.  I also predict this will generalize to arrays of any dimension (you already know it's true for dimension 1 ...)
Message 3 of 11
(2,088 Views)
Then output array size should be "0*0".
But I am getting array size as "0*3". Why it is because?
Message 4 of 11
(2,087 Views)
I think, whatever you have mentioned is right. But it doesn't meet my requirement.
Message 5 of 11
(2,076 Views)
Hi Alwin,
So the problem is your requirement/expectation…
What exactly is your requirement? The ArraySize function already tells you the array contains "0" elements…
Message 6 of 11
(2,057 Views)
Sorry for missing the details.
Since I am using this in a shift register, whenever  data comes in the next iteration (if it is lesser array size - expected array size is the array size of incoming data), it automatically creates array size matching with this size. So extra columns getting added.
Below am attaching the recreation of this bug as a VI. Please explain me, why 0's getting added as column in the output array even my source array size is always "10*5".
Message 7 of 11
(2,036 Views)
Hi Alwin,
please downconvert to LV2019 to receive more/faster help. Many of us don't use the very latest LabVIEW versions…
Message 8 of 11
(2,021 Views)
Det problem does not seems to be with the delete from array, but a "Insert into Array" in combination with your delete.
If you remove/disable the Insert into Array, then it will function as you expect.
Message 9 of 11
(1,998 Views)
The Delete From Array only subtracts the size from one index.  In your case, it is subtracting 10 from the row index size, leaving it as 0, but the column size is not affected.  Then when you come back around, the Build Array adds to both sizes.  The Insert Into Array only adds to the column size, leaving the row size alone.
I know this has been hammered out many times on this board.  I just don't have the time to dig at the moment.
Message 10 of 11
(1,995 Views)
