Bug in conditional for loop with an empty array
There appears to be a bug in the for loop with a conditional terminal.
If an empty array is wired to an auto-indexed array input tunnel, an output array tunnel has one element instead of zero.
 For loop bug example
The array constant on the left is empty.
Top loop without the conditional terminal produces an empty array.
The bottom loop with a never true conditional terminal produces an array with one element
Using LabVIEW version 8.5
Message Edited by TrevMrgn on 05-05-2009 02:01 PM
Message 1 of 19
(5,784 Views)
Just for info - this doesn't occur in LV8.6. Both array indicators are empty.
Thoric (CLA, CLED, CTD and LabVIEW Champion)
Message 2 of 19
(5,776 Views)
i also don't see this behaviour. Tested with LV8.5.
Mike
Message Edited by MikeS81 on 05-05-2009 04:14 PM
Message 3 of 19
(5,750 Views)
When constant folding was first introduced there was a bug that would show up only if either
Options >>> Block Diagram >>> Show Constant folding of wires
or
Options >>> Block Diagram >>> Show Constant folding of strutures
was turned on.
maybe that makes a difference?
Ben
Message 4 of 19
(5,738 Views)
Nor in 8.5.1 in WinXP SP3.
Message 5 of 19
(5,733 Views)
Ben,
I cannot replicate this behaviour in 8.5.1 with any of the constant folding options on and/or off.
Looking at the author's screenshot, constant folding of both wires and structures is on.
Message 6 of 19
(5,721 Views)
Hi Ben,
yes that's it.
Mike
Message Edited by MikeS81 on 05-05-2009 04:45 PM
Message 7 of 19
(5,713 Views)
I have done some more testing on this.
Creating the example from scratch, I do not see the error.
If I add one or more elements to the array (constant or control), then delete them all (using 'Delete Element') the bottom array has one element.
If I empty the array (using 'Empty Array') both are empty.
Also if I create an empty array using 'initialise array' with zero elements, I get one element.
'Show constant folding' does not appear to change the behaviour, but including a random operation in the loop does.
Trevor
Message 8 of 19
(5,702 Views)
Please post to demonstarte this condition along with a step by step instructions to reproduce it.
It we can follow your instructions and reproduce it we can log this as a bug.
Lacking the ability to reproduce.... there is very little any one can do.
Ben
Message 9 of 19
(5,691 Views)
Neither do I.
Nup. Still empty.
Yep.
Nup. Still empty.
Agreed that constant folding doesn't cause any odd behaviour. Introducing a random operation (adding two constants) in the loop doesn't either.
I've tried all your methods here Trevor, but I can't replicate this behaviour in 8.5.1 under WinXP SP3. Sorry! Smiley Sad
 Maybe somebody else will be able to help, or find a useable workaround.
Message 10 of 19
(5,689 Views)
