Bug in Get Image Method on Control
Great.  This is actually an acceptable solution because the update mode of a VI not being seen shouldn't matter, all you are looking to see is a single static image of the graph not update it continually.  If you were then the graph would be in a VI that has the front panel open.  Is it still a bug that the UI looks different?  I guess that's for someone else to decide but for now I concede, still not ideal and I predict someone in the future will post a similar question on the forums and (hopefully) find this thread.
Message 11 of 11
(806 Views)
