Bug Report
When using measurement units, occasionally one needs to square a value. for example a distance to form an area, or a current or voltage value to do power calculations.  Wiring the value with units to both inputs of a multiply function behaves as expected. The value is squared and the unit becomes a unit squared. However when using the square function, only the value is squared. The unit remains the same.
(4,017 Views)
Have you reported this to NI?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,989 Views)
This has been brought up before.
(3,950 Views)
Hi All,
This problem is a bug and it has been documented. For your reference it has been documented under CAR ID# 47360.
Eli S.
(3,931 Views)
