Bug (Front Panel)
(sorry for my bad english)
This problem occurred while I was coding.
My block diagram was in full screen mode.
when I displayed again the Front Panel, I have seen this "wide black line". (impossible to remove it.)
I have not succeeded to reproduce this behavior.
attachment : Bug_Front_Panel.vi - LV2014
Message 1 of 12
(10,782 Views)
Wow!  I have no idea how you did that, nor how to "undo" it.  What did you do?  That might give me, at least, a clue to what to try ...
Message 2 of 12
(10,766 Views)
"What did you do?  That might give me, at least, a clue to what to try ..."
I don't know, it is not I who had this problem.   here
Maybe the R&D team could analyze the attached vi and see where is the problem. (?)
Message 3 of 12
(10,747 Views)
So I changed the minimum panel size and it turns out LabVIEW immediately crashes when you only show the black bar on your front panel.  Maybe the crash will give a bit of information on what is happening.
Message 4 of 12
(10,721 Views)
Other things seem screwed up too, e.g. the horizontal scrollbar.
This is for NI to figure out. I would start over with a new VI and copy the code over.
Message 5 of 12
(10,638 Views)
Hello all,
Thanks for posting the issue, I created a corrective action request and hope to have this bug removed in next version.
Thanks again!
Jovan N. - Application Engineering
Message 6 of 12
(10,369 Views)
@Jovan.N wrote:
Hello all,
Thanks again!
What is the CAR number?
Message 7 of 12
(10,360 Views)
Hello Sir,
Car number is 535555.
BR,
Message 8 of 12
(10,354 Views)
perfect, thank you very much.
Message 9 of 12
(10,341 Views)
Interestingly enough, the black part doesn't actually appear to be part of the front panel.
if you use the front panel get image scaled method from the vi refnum the image returned doesn't show the black section.
Message 10 of 12
(10,285 Views)
