Broken wires with "Open FPGA Reference" connecting to a subVI
I have the same problem of JP205 but changing the all the controls and the indicators to dynamic is not an option.
Indeed, I am using a library tha comes with the FPGA and I would have to perform this operation for 100 subVI or so.
The library contains subVIs that allow to configure ADCs and DACs connected to the FPGA (I am using a pair of NI 5641R) and it is fundamental.
Is there any other solution?
Thank you
Message 11 of 14
(750 Views)
unfortunately there isn't really another way to recreate the SubVI's in dynamic mode other than the method that was described.
Ryan
Message 12 of 14
(735 Views)
What about casting one of the FPGA reference to the correct typedef by using a "Type Cast" function?
Could it work?
For instance, figure FPGA_reference1.jpg shows a snapshot of the code that references the first FPGA; figure FPGA_reference2.jpg depicts a similar piece of code, but in this case the second FPGA is referenced. The codes are meant to run in parallel.
It seems that a type cast has removed the conflicts with different typedef FPGA references.
Message 13 of 14
(721 Views)
