Broken wire in Excel Library routine
I have an application that works under the development system, but I get the following error when I build.
A VI broke during the build process from being saved without a block diagram. Either open the build specification to include the block diagram of that VI or enable debugging to include the block diagrams of all VIs in the build. Report this error to National Instruments technical support.
C:\Program Files (x86)\National Instruments\LabVIEW 2018\vi.lib\addons\_office\excel.llb\Excel Sort Data.vi
If I "Enable Debugging" for the build, the build error goes away, but I get an execution error that the Excel Sort Data.vi has a broken wire. Opening that VI shows that there is a property node that has required inputs unassigned. How do I recover from this?
(2,946 Views)
Well, attaching your code so we could "see for ourselves" and suggest a fix would help.  There has been a change in recent versions of Excel that may be the culprit, though it usually shows up as a Broken Wire when you run the code, but maybe you aren't using the troublesome function, but it gets "included" when you do a Build ...  Don't know, can't test (no code to test ...).
(2,910 Views)
Are you using report generation tool kit?
if yes then this may help you.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019N7CSAU&l=en-IN
(2,885 Views)
