Boolean
When you post a VI, it does not include any subVIs that are in your main VI. Each VI is a separate file. You posted SaveDatawithDelay_1 and on the block diagram, there is a subVI called SaveDatawithDelay. It is this subVI that needs to be posted. The easiest way to post a main VI and it's entire hierarchy is to go to Save with Options and select Development Distribution. This will create an llb that you should post.
Message 11 of 16
(1,252 Views)
Here is save data with delay function.
Message 12 of 16
(1,248 Views)
see the attached .llb.
Message 13 of 16
(1,245 Views)
Message 14 of 16
(1,244 Views)
I almost included in my last post that I would have guessed you had put a while loop in the subVI with a front panel stop button.
When you do something like that and don't make the front panel of the subVI visible, then there is no way to click the stop button and the subVI will just run forever until you click the abort button. Also, basic programming says that a function will not return a value until the function finishes. Since the subVI never stops, you never get a value back from it. The simplest thing for you to do right now is to put the small amount of code of the subVI in your main VI. The main VI you created doesn't do anything anyway. Your main VI should have the while loop.
Message 15 of 16
(1,242 Views)
Thanks for the valuable feedback. I will try this on monday, and let you know the status.
Jey
Message 16 of 16
(1,238 Views)
