Boolean
How can I create boolean output toggle everey 30 mins, for 100 loop.
True is on for 30 mins
False is on for 30 mins
Jey
Message 1 of 16
(6,766 Views)
Toggling is easiest done with a shift register and an "invert". Here's a code skeleton to get you started.
Message Edited by altenbach on 12-15-2006 09:08 AM
Message 2 of 16
(6,759 Views)
If that's what you want, then just add a shift register to my answer in your other post.
You should really keep follow up questions in your original thread. You should also probably look into the resources available for learning LabVIEW basics at http://zone.ni.com/devzone/cda/tut/p/id/5199
Message Edited by Dennis Knutson on 12-15-2006 10:10 AM
Message 3 of 16
(6,760 Views)
I appericiate for you time guys.
Thanks again
Message 4 of 16
(6,733 Views)
My application purpose, need exit from loop. Both cases, still running the loop, not going to savedata.vi.
How can I fix this ?
Jey
Message 5 of 16
(6,722 Views)
What do you mean? You can't exit a for loop early but the while loop has a stop button. It will exit whenever it's clicked.
Message 6 of 16
(6,715 Views)
Please see the attached program, The output always is false.
Message 7 of 16
(6,710 Views)
You have missed the subVI......Smiley Very Happy
Regards
CLAD
Using Labview 5.1,6.1,7.1.8.0
Message 8 of 16
(6,708 Views)
What sub vi? It works fine within function itself. If you call this function, the output always false.
Message 9 of 16
(6,705 Views)
The "savedatawithdelay.vi"...
CLAD
Message 10 of 16
(6,701 Views)
