Boolean enabling on front panel, but not in the block diagram
I have a boolean controller on the front panel turning on but it is not activating in the block diagram. The Boolean is inside an event structure. I have uploaded my VI for review
Update: clicking any boolean causes my VI to slow way down
(1,822 Views)
  1. Throw that away.
  2. Learn how to properly code in LabVIEW.
  3. Start over.
(1,798 Views)
Can you help? I need constructive criticism
(1,782 Views)
Accepted by topic author Kerbies
As some more constructive criticism - I suspect you have mis-understood:
  1. Data flow. LabVIEW forces you to think differently to how you may be used to programming in a single-statement, imperative way. It makes you instead think about data and how it is used/transformed within your application as it runs. A function ("node") only runs once all the data is available for it to execute. This is more closely aligned with Functional Programming. https://www.ni.com/getting-started/labview-basics/dataflow
  2. How event structures work. Event structures execute exactly one waiting event at a time, then exit. To handle multiple events, you need to house them in a while loop or similar. https://zone.ni.com/reference/en-XX/help/371361R-01/glang/event_structure/
It would be worthwhile for you to go through the LabVIEW tutorials starting here: https://www.ni.com/getting-started/labview-basics/
(1,777 Views)
