Boolean button stays pressed
I made a application with some boolean buttons.
No I'm having the following problem:
After I build the project and test it, the buttons are not pushed (False).
That is excactly what I want.
But when I connect it to the PLC, there are some buttons that are pushed (TRUE) automatically.
In my opinion it is very strange that some buttons do that, beceause they al have the same operation: "Switch Until Released".
Do I have to change the operation?
When I have to do this, it is very strange that some buttons work properly, and some buttons not.
I hope someone can help me.
Greets.
Message 1 of 10
(7,513 Views)
You can use a invoke node and select "reinitialize to default".
Message Edited by muks on 03-22-2010 04:04 PM
Message 2 of 10
(7,507 Views)
make sure that all your boolean buttons have the property "Latch when released" (offcourse based on your application)
Or there might be a chance that you have created some locals or property nodes which are wired with a true constant
Guru
Regards
Guru (CLA)
Message 3 of 10
(7,506 Views)
What does that sentence indicate? I suspect:
- Frontpanelbinding
- Reading shared variables/datasocket and writing data to the buttons (variables/property  node "value")
Without seeing the code, it is impossible to tell what is going on....
Norbert
Norbert
Expert: Geometry
Message 4 of 10
(7,500 Views)
Is it also OK when I use the "Switch Untill Released" operation?
Beceause most of the buttons that I use have this operation.
But some are staying switched, very weird.
But I will try to do the handlings that Muks said.
There are no locals or property nodes, so there is no constant true.
Message 5 of 10
(7,496 Views)
Norbert,
There is a variable coupled to the button.
The variable stands in a DB (as boolean ofcourse), and this is coupled in a program.
The variable is just used to reset the variable.
In my opinion the variable is nowhere set to TRUE.
So what can the problem be?
Message 6 of 10
(7,494 Views)
And if that doesnt help post your vi so that we can have a look.
Message 7 of 10
(7,491 Views)
I have NEVER seen buttons to change their value just on their own. This is independend of the setting of the button....
So there has to be some code changing the value of the button.
Norbert
Norbert
Expert: Geometry
Message 8 of 10
(7,489 Views)
Norbert
I too accept and feel you will atleast be using a case structure where the value is getting set and not getting revoked. Just a pure guess.:smileywink:
Message 9 of 10
(7,483 Views)
To stop everyone having to wildly guess could you just PLEASE post your code. Im sure that someone will take the time to look at it and rectify.
Thanks.
"Everything should be made as simple as possible but no simpler"
Message 10 of 10
(7,446 Views)
