Bluetooth
Hi All,
I want to check the data transfer between to Bluetooth device.  Basically I want to check the compatibility between two Bluetooth devices.
Please let me know if it is possible through labview & what are the hardware required for testing the Interoperability of two bluetooth device.
Thanks in Advance
Himanshu
(4,236 Views)
See here
How Do I Make a Bluetooth Device Work with LabVIEW?
Message Edited by muks on 04-30-2010 07:14 PM
(4,227 Views)
Helped? Anyupdate?
(4,197 Views)
Hi Muks,
Thanks for the reply.
I gone through the link provided by you. I need the hardware which can detect the pairing between two Bluetooth devices(one master & Other slave){i.e.. piconet synchronization}.
Is Labview having any VI or library which can capture , decode & display the data in real time.
HKT
(4,177 Views)
Yes labVIEW 8.x does support bluetooth
(4,172 Views)
(4,165 Views)
