Bluetooth problem
That's correct, due to the sheer amount of drivers out there LabVIEW uses only one's supported by Microsoft Bluetooth Stack or WIDCOMM driver sets, to ensure we can offer the stability required. The only way around this would be to use a bluetooth dongle supported by either of these for the Laptop, and also a bluetooth module card for your PDA that is supported.
All the best,
Applications Engineer
Message 11 of 24
(2,882 Views)
Hi Rob,
Regarding to this issue, i had to drop the Bluetooth and switch it to WIFI.
Is it possible for me to connect two PDA via WIFI?
If so can you give me some hint on the setting for it?
Thanks.
Message 12 of 24
(2,868 Views)
Hi Wyatt,
I'd recommend linking your PDA upto the PC via WiFi either via Ad-Hoc (directly) or through a router, and try and TCP Simple examples to ensure you get throughput and both devices can see each other.
All the best,
Message 13 of 24
(2,862 Views)
Hi Rob,
Which mean i can't link both PDA by PDA WIFI but it can be done through a Wireless Router, right?
I had try the TCP server and client VIs on my laptop and the PDA. It work fine.
Thanks for fast reply.
Message 14 of 24
(2,859 Views)
You can do it 2 ways,
1. Ad Hoc which is connect the PDA to the Laptop Directly
2. Have the PDA and Laptop connected via a router
Both outcomes will require you to know the IP of the PDA and Laptop but will work equally well, once the wi-fi link is up and running the examples will show you how to architect the wireless in LabVIEW (Server and Client). As you've moved from Bluetooth to WiFi I'd suggest starting a new post with a relevant title for any future questions on this - that way people can find it and answer you better under the forums.
All the best,
Message 15 of 24
(2,852 Views)
Thanks for the info.
Message 16 of 24
(2,849 Views)
Hi all, i need some help, i m searching for a Program with labview about transmission protocol   between PC and PC
I need this Program as soon as
Thanks a lot
Mehdi
Message 17 of 24
(2,744 Views)
Stop hijacking other people's threads!  Smiley Mad
You have posted this same message in 5 different threads.
Create a new thead with your question.
Message Edited by smercurio_fc on 06-30-2008 02:11 PM
Message 18 of 24
(2,743 Views)
I'm from Brazil
Bom dia Bob, tenho erro semelhante(BT10022) no PDA, eu consigo executar o PC mas no PDA o cliente não executa. Tenho Smartphone com WinCE 5.0, qual drive tenho que instalar no mesmo para poder ser reconhecido pelo Servidor(PC)?
Message 19 of 24
(2,517 Views)
I'm from Brazil
Helton Castanheira
Brasil - Belém PA
Message 20 of 24
(2,516 Views)
