01-26-2009 10:53 AM
I am using the bluetooth client/server example with labview 8.6. The severer reads my bluetooth adress but the client won't connect (error 59) , the adress and channel i typed into the client are correct, i am using vista and don't know if this is the issue.
Any ideas cheers?
01-28-2009 09:53 AM
The build in support that LabVIEW has for Bluetooth only supports the native Microsoft Bluetooth and a limited set of hardware. For example, if you have a dell preloaded with the Toshiba drivers for Bluetooth, LabVIEW will not detect your hardware and have similar issues to what you are having.
Amit
01-29-2009 04:15 AM
Hello Zac,
I hope you are doing fine. Could you please specify what hardware are you using? Basically error 59 means that the network is down, unreachable, or has been reset.
Please have a look at the following forum post as well
http://forums.ni.com/ni/board/message?board.id=170&message.id=255170&requireLogin=False
