Bluetooth devices
Hello everyone,
I would like to control our large roll-up doors in several of our buildings. I was thinking of installing Bluetooth switches in parallel with the up and down buttons and then creating an HMI that can run on a tablet that will be mounted on the hilo's that the employees use. Basically, a screen with buttons that when they pick a building, there will be the doors for the building, they will select the door, and then another sub vi will have an up or down button and a stop button, just like the local buttons by the doors. From what I have seen, I know we can use LabVIEW for this.  Has anyone done anything like this? I need some advice on what the best Bluetooth switch to use that works well with LabVIEW.
Roy Costa
Controls Systems Engineer
Motor City Stamping, Inc.
rcosta@mcstamp.com
Message 1 of 8
(2,204 Views)
@TheGreekTechMan wrote:
Hello everyone,
Roy Costa
rcosta@mcstamp.com
Hello, sounds like a good project. LabVIEW will work to make the application. You might want to look into the range before you go Bluetooth, I think it's limited to 30ft. Tcp/ip is a good option, lots of support and many iot devices to choose from.
______________________________________________________________
Have a pleasant day and be sure to learn Python for success and prosperity.
Message 2 of 8
(2,146 Views)
I am not familiar with such BT switches, so my only advice there would be to see what kind of API they have and how you're supposed to connect to them.
What I will suggest is to rethink whether you want to allow someone to close a heavy door that they can't see. I think that this the kind of action where you want to have the operator right there to see what's going on.
___________________
Try to take over the world!
Message 3 of 8
(2,096 Views)
I agree with you 100%. That’s why I’m only going to use Bluetooth. That’s good for 30 feet.
Message 4 of 8
(2,078 Views)
Message 5 of 8
(2,076 Views)
Here is what I’m going to use.
https://www.shelly.cloud/en-us/products/shop/shelly-pro-2pm-1
That looks like a nice unit but what I don't see (in my 10 second search) is an API for bluetooth, they only say:
Bluetooth
Add devices fast and easy via Bluetooth connection, using the Shelly Cloud App.
And searching the API says (no results found)
Maybe you can find something I am not seeing. If you cant find a bluetooth API, you are going to be doing a lot of hacking to get it to work.
Message 6 of 8
(2,064 Views)
Message 7 of 8
(2,061 Views)
Accepted by topic author TheGreekTechMan
Here it is. 🙂
https://shelly-api-docs.shelly.cloud/gen1/
Well, looks like it's time to get coding 👍
Message 8 of 8
(2,055 Views)
