Bluetooth Server and Client VIs Problem
Hi.
I tried to work with the Bluetooth VIs that were available in LabVIEW 7.1. I am using a DELL Inspiron model 6400 which comes with a Bluetooth adapter of Broadcomm. When I started the Simple Bluetooth Server VI with the Client open it gives me a error message saying that the : - "Error 58 occurred at Bluetooth Create Listener in Simple Bluetooth Server.vi.
 Possible Reasons: LabVIEW:  The network function is not supported by the system. "
Wat sud I do?
Please help!
Thnx.
Gokul.
(2,969 Views)
LabVIEW is not compatible with Broadcomm drivers.  You will need to try and uninstall those drivers and use Microsoft drivers instead.  A quick search on the web should help you through that process.
(2,952 Views)
