取消
显示结果
搜索替代
您的意思是:
Bluetooth Read VI error - simple bluetooth client/server
I've been able to run both the simple and advanced bluetooth LV examples, but I can't make the simple code below to work between my laptop and my PDA. Connection is established, but the Bluetooth Read VI returns an empty string.
Thanks in advance for any ideas.
Server
Client
0 项奖励
1 条消息(共 3 条)
3,649 次查看
Hello, Take a look at the link below, it has a lot of information about using bluetooth within LabVIEW. http://digital.ni.com/public.nsf/allkb/921795DD63E315B686256DD60082B252?OpenDocument Thanks. Best Regards
Luciano Borges
Test Development Engineer
0 项奖励
2 条消息(共 3 条)
3,587 次查看
Hi glauber,
 You must wire the bytes to read input of the read function.And also it is better to use Carriage Return and Line Feed string constants in the client program.
Thanks and regards,
srikrishnaNF
Srikrishna
0 项奖励
3 条消息(共 3 条)
3,584 次查看
