Blocking noise detection
Hi all,
im looking to a solution to dectect blocking noise. As hardware, a 5112 and
a 1411 is available.
Does somebody has a solution???
Thanx
Matthias
(3,057 Views)
Mathias,
I would be happy to help you come up with possible solutions for your application. For me to do this, I need for you to describe in more detail your application: the signals you are acquiring, the sampling rate you want to use, what are the phenomenons that you want to detect, etc.
Hope to hear soon from you,
Claudia Lorente
http://www.ni.com/ask
(3,057 Views)
Holy cow, that's the nicest answer I think I've ever seen! If every forum was this pleasant, a lot more would be acomplished (where's the spell check on this forum?). Cheers to Claudia!
2006 Ultimate LabVIEW G-eek.
(3,057 Views)
Agreed!
That's one of the reasons I subscribe to Claudia.
What's more she knows what she is talking about.
Ben
(3,057 Views)
Hello Claudia,
sorry about my delay, but i´m still on holiday....
I try to explain...
I have to test a DVD player, whether the playback of an moving image is ok
or not. If it is not ok, then there are normally blocks (blocking noise)on
the monitor.
Measuring of the digital-datastream is not possible, so i have to test the
analog video signal (CVBS).
Hardware available: scopecard 5112, grabber 1411
Thanx for your help!!!
Greetings
Matthias
(3,057 Views)
