Blinking of a single element in 2D array
Hi all,
I have a 2D array of clusters. The elements of the cluster are 3 different numeric data types.
Now, I want to programmatically blink a single element of the above mentioned 2D array (cluster as whole). Also I want to blink a single element of the cluster residing in the 2D array. Pl suggest me if there is any better way to execute this.
will be great to have your views.
-Sreedhar
Message 1 of 8
(4,388 Views)
Hi Sreedhar,
in an array all elements share the same properties. Their only difference is the value. So you can't set a single element to blink...
Message 2 of 8
(4,385 Views)
Funny undefined behaviour^^ Initial state undefined; hover with mouse over the control to hightlight arrayelements. Ups
RZM
Message 3 of 8
(4,377 Views)
Thanks for your replies. I would like to know weather it would work, if I make it a cluster of clusters ? how will the performance hit ?
Thanks again.
Message 4 of 8
(4,352 Views)
Thanks again.
Yes that will work!
The performance only becomes a factor if you are repeatedly moving data around. No move, no load.
Ben
Message 5 of 8
(4,346 Views)
Excellent...
Ben, could you please explain me what is the meaning of "Moving data around. No Move, No Load".
since it is a cluster of some elements, I will dynamically change the data. change the colours at the run time, blink etc. But will not move the cluster.
Regards
Message 6 of 8
(4,301 Views)
Sreedhar T wrote:
Excellent...
Regards
Good question!
I'll try to answer and if others see holes in this apprach, please corect me.
"Moving data" can be spotted by looking for two signs. "Flow" and "Buffers".
FLOW
Flow is the easiest to spot and is what you see when you se the data bubbling along while watching your diagram in execution highlight mode (light bulb on).
BUFFERS
Buffers are more subtle but you can se them whenever you use Tools>>> Pofile >>> Show buffer allocations. LV will work be hind the scenes to schedule your code to accomplish what you want while minimizing the need to duplicate your buffers. So you have to look for the bufers.
So if your code show flow to a buffer the CPU has to do work to accomplish that move.
How devistating will A move be? The actually load from a move dpends on how much data is being moved AND how often.
I'll call that a start and watch for others to offer their insight.
Ben
Message 7 of 8
(4,282 Views)
Another approch could be to set the background to transparent and use a decoration or string behind the control that you move to highlight a single cell. It is a complicated way to ge tthe same effect. Then when you want to blink the whole array you change the array to the color that you want and turn on blinking. It woill take a lot of work but sometimes thats what you have to do.
Tim
GHSP
Message 8 of 8
(4,275 Views)
