Blinking indicator different when compiled vs. development environment
Thank you! I suspected this, but wasn't aware that I can add my own entries to the .ini file of the executable. Here is the .ini file of the executable:
[FrontView]
server.app.propertiesEnabled=True
server.ole.enabled=True
server.tcp.paranoid=True
server.tcp.serviceName="My Computer/VI Server"
server.vi.callsEnabled=True
server.vi.propertiesEnabled=True
WebServer.TcpAccess="c+*"
WebServer.ViAccess="+*"
DebugServerEnabled=False
DebugServerWaitOnLaunch=False
So if I add the entries from my LabVIEW .ini file:
blinkFG=transparent
blinkBG=transparent
the executable should behave like the development environment? Is there way to add them during the bild?
Message 11 of 13
(996 Views)
This old post helped me when I wanted to add AllowMultipleInstances to my ini file.
Jim
Message 12 of 13
(980 Views)
Thank you, That worked.
Many thanks to everyone who replied! Let me summarize how I made this work:
In the VI's front panel, I set the indicator properties to Red when True, Transparent when False. In the block diagram, I set (via property nodes) the indicator to be blinking, and visible when True, and not visible when False.
Then hand-edited the application's .ini file to add these lines:
blinkFG=transparent
blinkBG=transparent
blinkSpeed=500
and now the application (when run from the .exe file) behaves as I wanted it to.
Following 's link to the old post, I was able to insert a custom .ini file during the build.
Message 13 of 13
(972 Views)
