09-30-2009 05:43 PM
Hi JoeC,
Going back to your first post, you said when you added the second loop this continuous running of the top loop started. However if you run just the top loop of the code, it still have this problem:
What are you trying to acheive? R&D is trying to gain more understanding on your application.
Claire
09-30-2009 06:43 PM
Right now my application has a couple of loops running in the background doing RS-232 communication and collection of SPI port data that interfaces an AD7476A. There are 3 other loops displaying data on the front panel.
I am then using the event structure to monitor for touch panel interaction. It would be extremely beneficial to have this process sleep instead of continuously polling to see if something changed on the front panel. This would save CPU cycles monitoring if something on the front panel has changed.
10-01-2009 10:45 AM
Hi JoeC,
Thanks for this information. Let me put together some more examples to demonstrate the problem to R&D.
Claire
10-02-2009 09:04 AM
Hi-
I am filing a Corrective Action Request to R&D about this issue. I will post the number for the CAR once I file it.
10-02-2009 04:39 PM
Hey JoeC,
The correction action report number is 190016 (if this issue is fixed in future releases, the fix will be linked with this number). I will let you know if I hear of any progress on this issue.
Claire
