Bitwise left shift in formula node.
Additional: The CRC, which I am attempting to emulate, is encoded in this site:
https://www.lammertbies.nl/comm/info/crc-calculation.html
This version :    CRC-CCITT (0xFFFF)
Message 11 of 21
(4,288 Views)
Trick for snippets
Use the picture viewer to download the snippet then poof code.
And either of the should do a CRC 16 ITT
"Should be" isn't "Is" -Jay
Message 12 of 21
(4,285 Views)
Accepted by topic author Barionics
Found the right combination of settings.  So here is a reduced version of my code that will work with your algorithm.  It does not use the lookup table, but it is simple and works.
Message 13 of 21
(4,277 Views)
Tim I swear that code is in my reuse library.
You may need to byteswap the output
Message 14 of 21
(4,273 Views)
Fantastic!   Thanks for your efforts.  I can't wait to try it!
But I must ask the question again, how to get it into LabVIEW without having to draft it all in line by line?   I tried cutting and pasting the PNG and looked for a POOF option (or even PROOF?) but no joy.
I must be one of those daft things which you have to just know and I'll be slapping myself.
Message 15 of 21
(4,271 Views)
@Barionics wrote:
I am attempting to convert a CRC calculator, written in C, to a LabVIEW VI.
It looked easy to cut and paste the relevant calculations into a formula node, but I have come unstuck.
in C I can do:
ushort value = (ushort)(I<<8)
The second 'ushort' is there to remove any overflow characters by chopping it back to 8 bits.  I tried replacing the ushort with uInt8 but no joy.
If I do without the (ushort) LabVIEW recognises the overflow and rounds the byte down to FF, which is not what I want.
The LabVIEW logical shift operator does work correctly, but, as the code is more subtle and clever than I am, I don't really want to go down the spaghetti route if I can avoid it.
BTW, don't think I hadn't thought to convert the C code to a DLL and import it that way, but I would need outside help with that, plus the complication of supporting the code.
Any help much appreciated,
  Ian
Is this what you are trying to do?
Message 16 of 21
(4,268 Views)
I think the use of "poof" was meant to be exclamatory, like a magician saying "POOF!"
The problem is that changes made last year to the forum software have broken snippets. Most of the time the image the forum shows you has been rescaled or had the LabVIEW code stripped from it, so you can't just drag or copy-and-paste it into LabVIEW anymore. It is still possible to save the image to disk and then open it in LabVIEW. There's a whole discussion about it here: https://forums.ni.com/t5/Feedback-on-NI-Community/Snippets-are-broken/td-p/3658760
Message 17 of 21
(4,266 Views)
Here
Message 18 of 21
(4,262 Views)
Also, what version of LabVIEW do you have?  Crossrulz's snippet is in LV 2016.  Paul's is LV 2018.
If your LabVIEW is older than the picture you are trying to drop in, it will not turn to code, but remain an image.
And as arteitle said, changes made to the forum in how it handles images have made things more complicated.  And exact procedures may vary depending on which browser you use.  But essentially, download the image file to your desktop.  Then drag and drop the file to your block diagram.
Message 19 of 21
(4,253 Views)
It (the generic version) has been in mine for around a decade now.
Nope.  It perfectly matched the example from the web site.  The Byte Swap will only be needed if the OP needs it to be Little Endian.  But, yes, I have seen that variation on CRCs as well.
Message 20 of 21
(4,247 Views)
