Bitmap Animation
I'd like to do the following:
1. Open a folder that contains BMP files using the code posted by SteveChandler
2. Display bitmaps in the picture object (say 1 image per second) in a way that would stretch the image and fiill the whole frame with every bitmap update.
Right now I do not see a way of stretching the pitcure object. I am not sure if I am using the right object (picture). Any suggestions are appreciated.
Message 1 of 14
(5,138 Views)
The picture control (which is called a picture control despite almost always being used as an indicator), has a zoom property which is perhaps the simplest way to get what you are after.  This assumes you want the same scaling in x and y which is fairly reasonable.  There are other interpolating methods for nonuniform scaling, but this is much more complicated.
Message 2 of 14
(5,134 Views)
Are you talking about Classic > Classic Graph > Control > 2D Picture? I do not see any zoom properties for this object.
Message 3 of 14
(5,130 Views)
Right-Click -> Create Property Node -> the last entry is 'Zoom Factor' or something like that.
Message 4 of 14
(5,125 Views)
Found it; but it does not work quite well. I need a have a separate zoom for X and Y axis, and the zoom factor is the one that works for both axis at the same time.
Message 5 of 14
(5,114 Views)
If you look in the code I posted here:
http://forums.ni.com/t5/LabVIEW/Concatenate-Images/m-p/1152517#M506549
you will find the code I use to do arbitrary scaling on 24 bit images.
Message 6 of 14
(5,110 Views)
This is so complex... is there any simpler solution?...
Message 7 of 14
(5,072 Views)
Hi wprice,
Were you able to look at the ScaleBitmap.vi. It appears to be a solution that should work well for you application.
regards,
Josh
Message 8 of 14
(5,027 Views)
Where do I find it? I do tno see it under LV 2009 examples.
Message 9 of 14
(5,012 Views)
Click on this link http://forums.ni.com/t5/LabVIEW/Concatenate-Images/m-p/1152517#M506549 and then look at the bottom of Darin.K's post you will see and attachment called  CoryKArtworkGenerator.llb 685 KB. If you open that attachment you will a labview LLB Manger open with three vis in it. I believe the ScaleBitmap.vi will be useful for you. Let me know if you that works.
Josh Brown
Message 10 of 14
(4,988 Views)
