Binary to Decimal convert in reverse manner.
Dear all,
I have a binary data set which I want to convert using negative powers of two. For example I have a binary data
11101100100000000000000
which I want to convert in decimal using method below ( negative powers of two).
(1 * 2^-1) + (1 * 2^-2) + (1 * 2^-3) + (0 * 2^-4) + ... + (0 * 2^-23).
I have been successful till the part or reversing the whole data set but couldn't figure out the rest. Help is sorely needed.
Regards.
Message 1 of 32
(6,971 Views)
Accepted by NapDynamite
Hi Nap,
you can do that bit by bit - or with the whole number in just one step:
Edit: I added one possible "hard way bit by bit" solution as well..
Message 2 of 32
(6,962 Views)
Dear GerdW,
Thanks alot 🙂
Regards.
Message 3 of 32
(6,953 Views)
A simpler way would be to use the Reverse String function and then use the Scan From String with the %b format.
Message 4 of 32
(6,934 Views)
Dear crossrulz,
I tried your suggestion but I wasn't getting required result. I reversed the string and fed it into the scan from string block with the %b format. I couldn't get the value as I would get by trying the above mentioned suggestion.
Or may be I didn't understand your suggestion properly.
Regards.
Message 5 of 32
(6,913 Views)
Sounds like a job for Integer to fixed point cast:
Message 6 of 32
(6,906 Views)
@NapDynamite wrote:
Dear crossrulz,
Regards.
Nope. I misinterpreted something.  Sorry.
That integer to fixed point is a nice trick!
Message 7 of 32
(6,887 Views)
That would be a Binal (or what you should call the fractional part of a binary number), so simply do binary string to number and divide by 2^string length. (which is the top part of Gerds solution ^^)
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 32
(6,865 Views)
The hard way can be made quite a bit less hard, e.g. as follows. 😄
It is probably pretty fast (not tested, though).
Message 9 of 32
(6,855 Views)
Dear Willd,
I have a little difficulty knowing the purpose of constant defined that is connected to fixed-point type. This is the first time I'm using this function. Why do we have to change the encoding of this constant to unsigned, word length to 23 bits and integer word length to 0 bits? A little explanation would be appreciated so I could get a better understanding for problems in future.
Regards.
Message 10 of 32
(6,832 Views)
