Binary String to numerical binary array
How do you convert a "binary string" to a numerical binary array??
Message 1 of 11
(7,069 Views)
Here is one way to do it.  Somebody will probably come up with a better method.
Message Edited by tbob on 05-04-2007 05:22 PM
- tbob
Inventor of the WORM Global
Message 2 of 11
(7,067 Views)
Hi tbob,
In ur method for loop is not necessary.
-Kumar B
Message 3 of 11
(7,039 Views)
Of course we would also need to confirm that "binary string" really means 'binary formatted ASCII string, containing only the characters 0 and 1".
There are many other possible interpretations for the term "binary string". 😉
Triniboy, please give us an example of your input string.
Message 4 of 11
(7,036 Views)
Also, I am not so sure that "numerical binary array" really means "boolean array". 😉
Message 5 of 11
(7,028 Views)
Ya, I too... ! Smiley Wink
- Partha ( CLD until Oct 2027 🙂 )
Message 6 of 11
(7,020 Views)
tbob
Only a question: What means the constant 49 in the equal input?? Why 49??
Message 7 of 11
(6,338 Views)
Hi kantabra,
"49" is the ASCII code for the character "1"...
Message 8 of 11
(6,336 Views)
ohhhhh jaja, that's true. Now, I understand all.
Thank you very much!!!
Message 9 of 11
(6,332 Views)
Regardless of points altenbach brought up, i would follow the convention for boolean representations and do a compare against "not-equal 48".
hope this helps,
Norbert
Norbert
Expert: Geometry
Message 10 of 11
(6,328 Views)
